Hello all. I had question regarding the standard Stabil fuel stabilizer, red formula not the blue formula. I purcahsed another vehicle for daily use, so my car does more time sitting in the garage that actually being driven. Anymore I am lucky to be able to get it out once a month, and have only put 90 miles on the car since the last fillup in January. Anyways, after my last fillup, I added the correct amount of Stabil as listed on the bottle to stabilize the fuel. I will probably be adding Stabil at all times with the fuel, just to make sure it doesn't go stale.
Do you all see any ill effects of using Stabil at all times? With UOAs, does Stabil show to have any effects on the oil? Or should I be chaning the oil more frequent when using it?
