WHAT OIL FILTER DOES EVERYONE USE ????
I have an obsession of buying oil filters. I still have some filters from 2007 that I've never used because I would buy one and use it afterwards.
Pureone P30001: Bought it when they just changed the can design. I remember BITOG complaining about the over-glittering all over the openings and such. I still have 3 cans in my old filter stash.
Denso oil filters, some napa proselects are in my old filter stash that I might use after I use up my new filters.
This month I've picked up some cheap blue mountain filters, a napa 51773 2qt filter, a royal purple filter, a fram.
from now on, im using 1 kind filter and 1 kind of oil, quaker state hm 10w30 and motorcraft FL1A, all available at walmart low price every day :), jeep and weekent mustang use same oil and same filter
The Ford gets Motorcraft FL-500s and the Duramax gets AC Delco PF2232. I wouldn't have a problem using Pure Ones, but I get the MC and AC by the case. That makes them extremely reasonably priced.
Currently using D+ in the xB, and Honda OEM in the Ody. PureOne for both on the next OCI (April in the xB and July in the Ody).
I have a handful of PureOnes for the xB, and will continue with those. When current supplies are gone, I'll move to Puro Classics from WM unless I can find a better deal on a better filter in the meantime (like more PureOne rebates).
I used to be a pretty regular purolator user, but they are becoming harder to find. Been using e-core AC Delcos lately since they have them at walmart.
Walmart is now carrying Purolator oil filters.
Sounds great, but not around here. They have Fram, AC-delco, supertech and mopar.
I'm not sure which mart of MN you are from, but they should be working their way to you shortly. The first WM I saw them in was in Eagan, and about two weeks later the shakopee store was switched over. Some day soon they will be in your neighborhood.
