My first UOA. I have about 200 autocross runs and 50 drag strip passes on the car. The car has a slightly larger turbo, multiple dyno tunes, and some "breather mods".
I am obviously concerned about the lead. Since this is my only car, and I don't feel like having expensive maintenance done on my car, I would like to have another sample analyzed. I changed the oil and filter while taking the sample. How many miles is the minimum that I should drive before taking another sample to insure that the results are not just a one time thing? What could cause that lead number other than bearings? I took the sample from the drain. I collected it after the oil was draining for about a minute. That was the third oil change since installing the new turbo. Any advice would be appreciated. Thanks.
