I brought this up a while back and cleaned the carb out with no luck. I have used the tractor a few times this winter and the oil still smells strong of fuel. The level is correct and it runs perfect. The engine is a CH20 and it has a mechanical fuel pump that is attached to the valve cover. The kohler service manual says this is not serviceable. I have read a lot about the diaphragm leaking but i think this is on the pulse type pumps. Any suggestions about what this could be? Im thinking about getting a carb kit with a new check valve and double checking my float position. Other than this i dont know what to do about it. I hate that my oil smells so strongly of fuel.
