Castrol 75w-90 Gear Oil - Is it any good?
Nashville, TN, United States
I need to change my rear diff fluid here soon and came across Castrol's 75w-90 gear oil. They didn't have it the last time I was in the store so I went with Mobil1. It meets or exceeds the GL-5 spec and is about $4 cheaper than the Mobil1.
Is the Castrol a good fluid or should I stick with M1?
I don't have any Amsoil dealers close to me so it's got to be something I can get in an autoparts store.
I have used it in my Axiom's rear differential for 30K. When I changed it, there was very little metal on the magnetic plugs. I was able to buy Valvoline cheaper, otherwise, I'd have gone with Castrol again.
Hi,
Mossyoakglock - Castrol's synthetic gear lubricants are amongst the very best available. They have been long term players in the field (from the 1930-50s - well before BP took over) and many have their origin ex Germany
I have run comparison tests over many millions of Kms so I can "speak" with a lot of background knowledge
All my present vehicles have Castrol synthetics throughout their drivelines
Use with confidence - of course always use the correct specification for the application!
Thanks, Doug.
Fxrider made it sound like it wasn't synthetic but I could have just read the post wrong.
I run Mobil in my engine but Castrol in tranny and transfer case so I'll probably run it in my rear diff to keep all drivetrain fluids the same.
