My 12 years old 130+k miles E430 had the first problem with coolant system: some coolant leak on garage floor, after some detector works the leak was from the upper radiator hose at the neck of the radiator, the clamp got loose a little after 130+k miles. Tried to tighten it a little one day and the leak didn't stop, tighten it a little more the next day and still small leak, tighten it more on third day and broke the clamp.
Went to O'Reilly and found they have mostly made in China hose clamps, found the last made in USA package a little tight fit clamps at 1.75". Bought the made in USA and 1 size larger at 2.25" made in China clamps.
Put the made in USA clamp on, the fit was tight but no problem to slide it into place, stated tighten it and it broke.
Removed the broken made in USA clamp and put on made in China clamp without any problem, it is a little larger and doesn't look as nice as made in USA clamp, but it works and stops the leak.
Felt so bad about inferior quality of a simple clamp with "Made in USA" stamped on the package. Hopefully, this is an isolate quality problem and I'm still looking for made in USA parts when needed.
