im not science major or anything like that and i was curious to see if a magnetic drain plug can still magnetize metal objects when an engine is at full operating temperature. I heated water to boiling temp(212F which is around the temp oil is when fully warmed up), poured that water in a glass container and stuck a magnet holding a bolt screw and cotter pin in the boiling water. I shook the magnet vigorously in attempt to shake off the metal objects.
I read that a while back that magnets lose their magnetism at a certain temperature(curie temperature??) and this was just to confirm for myself that magnetic drain plugs are effective...since i run one in my engine and transmission. Not all magnets are the same, this magnet happens to be quite strong and the ones in my engine and transmission are even stronger. Theres no way i can replicate the situation inside an engine oil pan, but this is good enough
