Okay so I am putting together a stoker 409 for my fathers hot rod. Got a set of the 425hp factory iron heads. These have 3/8ths rocker studs in them. Back then the factory pressed them in and pinned them in place. My local machine shop is hesitant to take them out for fear of breaking one off. The holes the factory drilled in the studs are large. I want to put 7/16th screw in rocker studs in it so I can put roller rocker arms on it. Anyone know of a good cylinder head shop that deals with these sort of vintage performance heads that I could contact? Thats all I need done. I can grind the valves on my old Sioux machine and do the seat job myself.
