Here is the quote from Bob Alree:
A higher level of ZDDP was good for flat-tappet valve-train scuffing and wear,
but it turned out that more was not better. Although break-in scuffing was
reduced by using more phosphorus, longer-term wear increased when
phosphorus rose above 0.14%. And, at about 0.20% phosphorus, the ZDDP
started attacking the grain boundaries in the iron, resulting in camshaft spalling.
I wonder if he was talking about cast iron or steel cams?
But anyway, it does say that phos above 1400ppm could cause an increase in long term wear.
