Originally Posted By: Doog
I bought a used Honda Civic (2009) for my daughter to travel to college. It had about 40,000 miles on it which was pretty high but she will only drive about 5000 miles a year so in 2013 when she finishes school it should have about 60,000 on it and be 4 years old which makes it average. (I got a great deal due to the high miles). Anyway, I started using Quaker State Ultimate synthetic and notice the oil gets jet black in about 2000 miles. So I changed it at about 4000 miles and used the same oil again. Now this oil is jet black at 4000 miles again. I was wondering why this oil gets so black so soon? I mean it is so black it looks like crude oil. Is this a problem?
Looks like someone probably ran conventional oil for the first 40,000 or so miles, perhaps didn't change it as often as needed, who knows. Quacker State Synthetic is cleaning the engine. I would do the next oil change at 5,000 miles and than 6,000 miles or if you like 4,000 mile oil changes do that for awhile, but synthetics will go further. Do use a filter that won't load up as quickly, if your engine had lot's of deposits in it, it might put your filter in bypass mode if clogged. Suggest moving up to a synthetic media type filter, which has more holding capacity just to be on the safe side, such as Mobil 1 EP or Bosch Distance Plus, you can find them at Walmart.
