have an old schumacher se-1010 battery charger.
It is not the se-1010-2 that you fill find googling, in fact I cannot find a web image of what i have which is "SE-1010".
Problem I have is on a regular lead-acid car battery the charger will run up to 15.0 volts and higher. Was wondering if anybody might know what might be wrong with it.
It's just a metal box, has am amp meter on the front that reads 0-5-10-15 amps, an on/off switch, and a 6v/12v switch.
I had a deep cycle trailer battery that was severely discharged down to ~10.5 volts so i used this charger on it. It ran at around 8 amps for a few hours and brought battery voltage up into the 13 range. I checked back later and battery voltage was at 15.0-15.1 volts. I had a second battery nearby that was good and near full charge (12.55 volts) so I tried the charger on that and within 3 minutes the voltage was at 15 and the ammeter was showing around 4 amps.
