The '92 Lumina failed emissions tests today. Typically, it failed with high NOx readings. The test numbers are below.
Since the HC numbers are low, I'm going to assume for now that the cat is working (it doesn't necessarily mean the NOx section is working).
Since the measured O2 levels are also low, I'm also going to assume the mixture is not lean.
The vehicle does have an exhaust leak down stream of the O2 sensor and up stream of the cat at the exhaust manifold flange.
I don't think the exhaust leak is contributing to erroneous NOx readings (it might be contributing to the low HC readings comparing 2007 to 2011). Comparing 2011 test numbers to 2007 (I couldn't locate the test results for 2009) it doesn't seem that the NOx numbers differ that much from 4 years ago (25MPH test speed not withstanding). I know when and where the exhaust leak manifested itself. It wasn't there in 2007.
After I get the exhaust leak repaired (new head pipe), I'm going to focus checks on the EGR system.
Question: Should I repair the exhaust leak and re-test immediately or repair the exhaust leak and chase any EGR gremlins and then re-test?
Thanks for your comments and advice.
Curious Observation: Look at the maximum allowable numbers for HC, CO and NOx between 2007 and 2011. Notice anything strange? Yes conspiracy theorists; this is how the state of CA gets older vehicles off the road.
