What connection is there between oil viscosity and oil pressure? The engine in question is a 20r/22r hybrid that is driven like a race car. The owner indicated that 20w-50 wasn't cutting the mustard and the reason was that it wouldn't hold oil pressure at high rpm. At some point it seems that the oil pump wouldn't be able to keep up with the higher viscosity.
Any thoughts?
Any thoughts?
