I took my Jeep to a mechanic spittle while back because the steering wheel felt loose. I know I needed an alignment because I never got one since I bought the car used with 68k. Now the mechanic told me that he found a power steering leak in my rack and pinion and that it was worn and needed replacement. This is an $850 job, I don't have the money for that at the moment. I know I should have told him to show it to me, but I have yet to find the leak.
I went and got a 2nd and 3 rd opinion elsewhere, and the 2nd guy said I just needed an alignment, it was 80 bucks so I said what the heck it can't hurt. I never mentioned what the first guy said. After I got the alignment the steering wheel felt a lot better and the handling was a lot better as well.
I went to a 3rd guy thinking the 2nd guy might have missed something and All I mentioned was the symptoms of extra play in the steering wheel and steering wheel looseness and that I recently got an alignment done. The 3rd guy said everything was tight, then I asked him if he checked the rack and pinion and he said it was good and if the rack was bad the other guy couldn't have done the alignment. He also told Mr the tie rods are good
The first mechanic put this thought into my head and its Been hard to believe him and hard not to. My steering wheel is no longer as loose I think it responds well, I heard when the rack is about to go it makes noise and the whole steering system doesn't make noise at all. The Jeep drives straight with hands of the wheel,I have checked the power steering fluid periodically and its at the full mark even though its spittle lower than before because I have slight overfilled it by accident and never took it out. And I have yet to find a leak. I don't know if its headed in the right direction but I bought a bottle of Lucas power steering stop leak just incase it is a leak and I have to buy some time before I can replace it, even then I'm still skeptical about putting that stuff into my power steering system. So, does this add up that my rack is still good and the guy was just out to get me for my money?
