Originally Posted By: OldCowboy
Unless you have a new GM under warranty, which requires a 5W-30 dexos oil, I see no reason not to use 0W-30 year round. Even at 100F it will flow better at startup and provide the same operational viscosity and protection as a 5W or 10W oil.
Anyone who believes that a 5W or 0W is "too thin" simply does not understand the API viscosity system.
+1, Thanks Old Cowboy.
Critic, I would agree with you if this was under warranty but an oil like "GC" 0w30 is thicker anyway it has room to shear some and still protect this engine fine. M1 0w30 would be fine, M1 0w40 even better.
"GC" is over-rated IMO. It is not the formula it used to be but it is a good lube. As Buster mentioned M1 5w30 EP would be an excellent choice, Pennzoil Ultra is also outstanding. You have a lot of great choices...don't forget M1 0w40!!
