JHZR2
Staff member
Was trying to get some Christmas lights up, and plugged them into my outside outlet. Now, I installed this outlet about 1 year ago, and it has worked fine.
Go to run the lights, nothing. Breaker OK, voltage out of the breaker, voltage on the line in the box. Connections OK and I can sense voltage on the screws of the GFCI plug.
So the plug is bad. Leviton brand, guess where it is made???? China.
So is it cold weather (its like 33 out), or are GFCIs sensitive to cold (worked fine last winter), or is it a case of Chinese junk?
Plug was in a gasketed, sealed box and looks like new. No sign of any moisture or anything else.
