18sp transmissions are very common here in the usa. Most guys just have it for bragging rights as they are not needed in a regular otr truck.its basically a 9sp with a splitter in low and hi
You usually need to get an 18 speed transmission to get big horsepower rated engines as well. Light duty spec drive trains with big torque and horsepower usually don't last long when pulling heavy weight.
I'm talking about regular OTR trucks that only run 80K or less.I'm seeing many 550+hp engines and 18 speeds in these trucks and thats just not needed with 80K.
Sure in NV where they pull tripples a 18 may be needed but these are fruit trucks and such.
I agree there, 80,000lb gross doesn't really need 550hp to pull it, I think its all about bragging rights. Up here, I haul gravel with a tri-axle lead with a 3 axle pony-pup grossing 136,000lbs. The boss specs 550hp with the Cats and 565hp with the Cummins. He says he gets better fuel milage running higher horsepower, so thats why he does it. The Cummins ISX 565 motors seem to do a it better than the Cat engines in fuel milage for some reason. I like the way the Cummins pulls, but not how they shift.
I used to pull 80,000 lbs with a 300hp L10 Cummins and a 10sp. Man I hated that truck but it did the job every day for many years.
From there I went to a 430hp Series 60 which was plenty of power for all but the big hills .
