I was at my dealer this evening for a pre-winter inspection. (i.e. battery/alternator/starter check, top-off wiper fluid, etc.) It was free, so why not?
Anyway, the Service Advisor said that everything checked out fine, but there was something on the diagnostics printout that I questioned. The battery is rated at 550 CCA but measured at only 409 CCA.
He said a brand new battery rated at 550 CCA would test at that, but not a perfectly fine 3 1/2 year old battery like is in my vehicle. Does that sound right to you guys?
The car starts at the push of it's button without any hesitation or extra cranking. But with the cold weather just around the corner here in Southeast Michigan, I certainly don't want to risk a battery-related problem.
