Originally Posted By: heysteveh
Questions:
1. Is it worth it to use synthetic grease over regular?
2. If so, will it last longer and be more resistant to wash out, thus meaning I would have to grease less often?
3. What greases do you recommend?
Answers:
1. Not necessarily - IMO it comes down to what thickening agent is used and the additives that carry the load. If you want to spend the extra money make sure you are using the right grease for the right application.
2. Yes and no; Synthetic Greases typically mean the base oil that is used in the grease is Group III or Group IV (hopefully Group IV) this gives better base oil viscosity which usually ends up giving broader operating ranges. As far as I know using a Calcium based grease over a lithium base is going to give you better washout capabilities. High Moly content can help protect your grease points when the grease runs out and tackifiers are used by many companies to help keep the grease in place (stringy grease).
3. I try not to recommend specific brands but I would typically say that a calcium based grease is usually worth the extra money in consumption (typically 1/2 to 1/3 of cheaper lithium greases). Check the data sheets. If you are wanting to avoid greasing might I suggest an automatic grease system Lincoln makes several that are really good and then you just keep the tub full of grease and away you go. There are extra benefits to doing the greasing yourself though, while you are under the truck it's a good time to proactively look for other issues (springs, U-joints etc).
Hope it helps - IMO if you are doing regular greasing then it doesn't matter what grease you use.
