Hi,
2000 corolla CE 150k.
After a process of elimination with the engine (plugs, coils, vacuum lines, TB/iac/maf cleaning, etc) it would appear that the sudden rough idle at a stoplight may actually be vibration from a failed motor or transmission mount.
Questions:
Can a motor mount suddenly fail?
if so...
How can I tell which mount has failed? Symptoms are reverse and neutral perfect, drive real bad, park, less bad.
Questions:
if so...
