Originally Posted By: GMBoy
You can either have it cleared as suggested or wait it out until the proper number of ignition cycles pass - then the light will go out. I really do not recommend disconnecting the battery on late model cars...just too much that can go wrong. For one - your car will have to relearn all the driving parameter which should take less than 50 miles max, then you usually loose all your radio and other presets and that is a hassle, but thirdly - some cars loose power window positions and other items that you NEED to know how to reset or off to the dealer you go.
Disconnecting the battery is old school and no longer recommended. Go to autozone and get it cleared or better yet get your own scan tool - they are worth the price in what you save in doing your own work.
Thanks. Are you and Smokefan saying the same thing? I think he is saying the code is "hard" and will not clear itself but you are saying the code will eventually clear itself, right? You are 100% right on the scanner/code reader. I plan to get that situation resolved soon.
