Post your latest oil change
2010 Equinox, 33,400, PL15436 and 5 quarts of Castrol 0w30.
2006 Honda ST1300, 21400, PL14620, 4.5 quarts Brad-Penn 10w40 motorcycle oil.
2003 F350, 94,000, FL2016, 15 quarts of Delvac 15-40.
All this weekend...
2004 Malbu Maxx 87K 5qts Auto Extra(Ashland) 5W30 Purolator Pure One Filter
2003 Ford F150 94,115 5qts QS Q-HP/1.5qts Form Shell 5W30 Purolator Pure One Filter
Originally Posted By: KJK200
I did my VERY FIRST oil change on a car.
Car 2010 Nissan Altima 4 cyl
mileage is 39000
OUT: dealer bulk 0w-50
hastings filter (In car when I bought it on 8/31)
IN : Valvoline 5w-30 full synthetic
Bosch Distance Plus #3300
The hardest part was getting it high enough to get underneath it to get to the drain plug. BUT my neighbor who helped me today is installing a lift in his garage, so it will be ALOT easier next time.
I'd like to know when Nissan's starting specifying 0W-50 engine oil!!!
:p
mileage is 39000
:p
I was wondering the same.
1999 Explorer
Out: Unknown oil , Fram PH8A (from shop that did inspection) .
In : Mobil Super 5000 5w30 , Motorcraft FL1A .
2008 Honda Pilot EX-L
Whatever conventional 5W20 they use at Jiffy Lube
Whatever oil filter they use at Jiffy Lube
2006 Saab 9-3 2.0T
Mobil 1 0W40
Saab OEM oil filter
1993 Mazda RX-7
Auto Extra 10W40
Mobile 1 oil filter
At the Jiffy Lube near me, they use Formula Shell conventional. Jiffy Lube is either owned by or partnered with SOPUS (can't remember which it is), so you either got PYB, FS, or QSAD. Your receipt should state whatever they used.
2002 BMW 325Ci. Out M1 0-40. In M1 0-40. Mann filter.
Only 3200 miles on it, but in there 8 months. New fill will run the winter. Lots and lots and lots and lots of SHORT trips. Work is only 1.4 mi away.
I changed the Civic's oil this morning, I drained out Toyota 0w20 with 4400 miles on it, and replaced it with the same. We still don't have the SN version up here, so both the outgoing and ingoing oil was of the SM formula. I pulled off a Quaker State oil filter and the new one is a Fram XG.
I did the oil change with 50% oil life showing on the monitor, I did not feel comfortable running the very first interval right to the maximum amount, as the engine may have run nothing but conventional oil it's entire life (and it's got 83k on it) I also did not want to get stuck with the car needing an oil change in the middle of winter. It also allowed me to get a true reading on the oil consumption as I could measure how much came out. I put in 4L and about 3.7L came out, and I bet a good portion of that difference is oil that soaked into the filter media. So this engine most likely won't need topping up in between oil changes. (especially since the manual calls for 3.7L and I overfill it to a nice even 4L to keep things simple)
I took a sample and will be dropping it off at Wearcheck on Monday so I will be posting the UOA results on Wednesday or Thursday most likely.
