I'm having a issue with the drivers rear drum brake on the Escape. Back around 40-50k I snapped the bleeder off on that corner and had to replace the wheel cylinder. I'm guessing I didn't properly adjust it as the shoes were worn to the metal and the passenger side is still at 75%. The current problem I can't get the wheel to spin freely after I tightened down the wheel. If I leave it loose it's fine.
I have taken a wire wheel to the drum and made sure the back plate isn't bent. It did help till I started it up and drove around the block. Now it'll turn but stop in the same spot every time. I've adjusted it a dozen times and I'm sure it's not the brake shoes. The old ones wore fairly evenly. The only thing I can think of is the drum itself. Doesn't seem to affect brake operation but it does run 20 degrees hotter. It seems like it's always did that. On occasion it would turn freely and other times it won't. The other side never had a issue.
