^ Correct. They tend to be hard on oil if run with a blown plenum, but even then, it's not a sludge problem per se. It's more like bits of hard carbon that end up blocking the oil pump pickup. If the plenum is good, they'll stay pretty clean. When I had the intake off mine shortly after I got it (first 99k of its life was on bulk dino at 3k), it had light varnish, but not a hint of sludge.
