I did the B-12 Chemtool® Total Combustion System Cleaning Kit and thought that the hose that the B-12 is sucked into the intake might make a good way for "water carbon removal".
Would/could the small diameter hose and the three way "Y" connector in line of the hose used to vaporize the B-12 work to vaporize water too?
The system sucks the B-12 in the motor very slowly. Is the system slow enough to safely inject water with out worrying about damaging the motor?
