2009 Genuine Rattler 110 scooter; what 2T oil?
Palmyra, PA
the operator's manual for my leftover 2009 Genuine Rattler scooter is vague about 2-stroke oil usage; the scooter uses an injection system; what 'classification' of 2-stroke oil is appropriate to use? thanks
(eg: I get conflicting advice from use anything for motorcycles to use outboard motor tc-w3 oil)
PJ1 and Silkolene make oils specifically for injector lube 2 cycles.
it's probably only different than their pre-mix because it doesn't have a dye in it.
Injection system lubricants don't have the same issues with miscibility that pre-mix lubes have. They are generally a much different product in terms of formulation.
