This was run with nothing but 20W-50 conventional oil for about 1500 miles. I wanted to go more, but the canister was bulging from the cold starts and runs in the mornings, and I decided it was time for my "winter weight" 10-40 before I blew the filter gasket or something.
The oil pressure down stream from the filter (where the pressure regulator is on this engine) never got above 80 PSI, so I guess that's when the regulator was fully open, dumping excess oil back to the sump.
I don't know what the PSI difference across the media was--whatever it takes to bulge the can, minus that 80 PSI I suppose.
I have to say, the media on this Ecore® design held up well for what I think must have been a very high oil pressure across it.
But, on this particular filter, all the pleats are pretty straight and not laying flat on the center cage. It makes me think that the ones we've seen with holes cut in the media from the cage were probably due to the pleats laying flat against it where they would not be stiff enough. I hope this was a (fixed) QC issue only, and not a fundamental design flaw. I wish I could tell for sure if the pleats are straight and radiating properly away from the center cage for strength by looking into the center hole. If so, I would probably buy these regularly.
I'm still not "sold" on this design, but am posting this just for the sake of discussion.
