Help...wrong wix oil filter?
Kimberly, WI
2011 honda crv awd 2.4L, changed the oil and filter today picked up a wix 51356 filter i just now realized i should have gotten 57356 filter. I checked the Wix website and cant find the differance between the two, the numbers look the same the only differance is the canister color. Is the 51356 filter ok to use? Should i go back and get the correct filter? I was going to get the amsoil ea filter but grabbed the Wix at the last second thinking the Ea was over kill. What do you think
Weird! Purolator calls for the 14610 (Fram #7317) in the 11 CRV which is a direct cross with the 51356.
Specs look exactly the same for both Wix filters. Though looking at the 57356 can't tell if it has a silicone adbv like the 51356.
I say good to go with the Wix 51356. Don't return it.
I emailed Wix there has to be something internal that is different. Just curious, what do you think of the Amsoil Ea oil filters?
