And the $1200 car with a $6000 stereo and $4000 rims barely even runs, leaks/drips/burns oil, sometimes leaks gas too and it belches blue smoke out the exhaust so bad you can't even be near it whe it is running. A/C doesn't work and neither do the power windows, so it's a real treat to drive in summer, especially for the innocent kids in the back seat, who probably don't have a car seat, and even if they did, the seat belts are either broken or missing altogether. The heat doesn't work because at some point in time the heater core has been bypassed due to a leak and the blower motor either works only on high speed or not at all. If you are lucky one of the 3 brake light/tail lights works and maybe one of the blinkers works on one side only but neither one in the instrument cluster will flash so you have no idea if they work at all.
I used to see these kinds of cars all the time when I was a car stereo installer. We called them "hoopties", nothing on the car worked, engine barely ran, when it did run it usually had a bad exhaust leak and/or ran so rich the exhaust would make you sick to be within 10 feet of the car, usually the car had a lot of electrical and safety problems going on...but there they were, spending $300.00 on a new CD player, amplifier or adding more speakers to a stereo system that could be heard for 6 blocks. And the car was always spotlessly clean, has a $500 steering wheel and sitting on the biggest rims that would fit.
A lot of the time they would pay for the new stereo or whatever in cash. All in $1, $5 and $10 bills. I give you one guess as to the source of the money. Yet a lot of "those cars" all had one thing in common: most of them had an open Bible laid up on the dash. We all knew that usually meant the car belonged to a gang member. Most of their cars had a very "aromatic" interior when they showed up at the shop too.
And this is just about the cars. I won't get into the other aspects of that kind of lifestyle that ordinary working people have to support. I will say the sad thing is the kids grow up in it and that is what they are very likely to become too. They know nothing else and often have no one to teach them any better.
