Originally Posted By: TomYoung
Sounds like a failure of the fan clutch.
Maybe in 1975 it sounds like that. I would be shocked if this vehicle has an engine-driven fan.
This problem is simple -- for some reason the electric rad fans are not turning on when the engine is idling. Check more or less in this order, fuses, relays, solenoids, fan thermostat/switch and finally that the fans will run when receiving current.
He's already mentiond it has electric fans.
However, your assumption that vehicles today don't have engine-driven fans is false. Many trucks today still use engine-driven fans.
