Good day to all and my apologies for starting yet another "Engine Oil Recommendation" thread - I did search and whilst finding a few semi-relevant posts, none really hit the mark.
I have 2011 BMW 135i. This model uses the N55 engine rather than the older N54 engine - the key difference being that the N55 uses a single twin scroll turbo rather than the N54's twin turbo.
However this engine also has another key difference and that is that it uses BMW's fancy Valvetronic variable valve lift system which basically eliminates the need for a throttle plate as valve lift takes its place - Wikipedia Link
So that is why I say that I could only find semi-relevant info (ie none specifically on the N55 engine).
So the manual lists approved oil grades as:
It also says that alternative oil types must meet API SM or higher and then goes on to say that "BMW recommends Castrol".
The car is mostly driven on short trips (I know, it's a travesty) but it will see a few longer trips each year and some occasional track work (hill climb, AutoX, track day) - say 2 - 3 times a year. Total annual distance is probably around the 5-7k km mark (say 3,000mi to 4,500mi).
I live in a temperate climate (Melbourne, Australia) where winter minimums can go as low as -1*C (say 30*F) and summer maximums often hover around the 32*C (90*F) mark and can go higher but will generally not exceed 45*C (113*F).
So the question (obviously) is what would the experts among you recommend in oil and change frequency?
Given that BMW recommend Castrol, I'd guess that it would pay to start thinking there so the options available to me are:
So should I go for one of these Castrol oils or should I avoid them altogether and go for something else?
- BMW High Performance SAE 5W-30
- BMW Longlife-01
- BMW Longlife-01 FE
- Castrol Edge Sport 5W-30 (listed as SAE 5W-30, API SM/CF, ACEA A3/B3/B4)
- Castrol Edge Sport 0W-40 (Listed as SAE 05W-40, API SM/CF, ACEA A3/B3/B4 and BMW LL01)
- And finally there is 10W-60 and 25W-50 which I'm guessing would not be appropriate
