Ute has 225,000 km total mileage and is fitted with a Motorguard bypass.The recommended change interval is 5,000km with the FF filter every 10,000.I changed the FF filter at 20,000km and the toilet roll every 5,000 km.It requires 1 litre of oil for each roll change plus an extra 1 litre at FF change time,therefore has had 8 litres of top up.Columns from L to R are current at 40,000 next current at 30,000 next previous oil change at 25,000 and last oil change at 20,000 km.Missing elements are nil.
Cu 5,4,4,5
Fe 41,26,20,14
Cr 3,2,2,2
Pb 5,4,4,3
Al 4,3,3,2
Si 5,8,2,2
Na 2,2,4,2
Mg 12,11,10,10
Zn 1302,1245,1270,1193
Ca 3747,3633,3456,3424
P 1063,1017,1032,1019
B 1,1,2,4
Nit 10,11,10,9
Soot 54,52,33,29
Sul 38,45,40,40
Oxi 40,48,44,43
V40 92.4,91.0,89.4,87.8
PQ 8,2,-,7
Fuel Lab comments;The iron level has elevated.Other wear levels appear normal for the kms on the oil.We recommend to change the oil and resample in 20,000 km to monitor the trend.
Cu 5,4,4,5
Fe 41,26,20,14
Cr 3,2,2,2
Pb 5,4,4,3
Al 4,3,3,2
Si 5,8,2,2
Na 2,2,4,2
Mg 12,11,10,10
B 1,1,2,4
Nit 10,11,10,9
Soot 54,52,33,29
Sul 38,45,40,40
Oxi 40,48,44,43
PQ 8,2,-,7
