The generator also has pull start. The electric start is for the wife.
Here is a description of the generator
The ETQ TG72B12 has a power output of 8250 watt surge and 7250 watts of continuous power. The ETQ TG72B12 is powered by an ETQ 14 HP, 420 cc, 4 Stroke, air cooled heavy duty engine and with a fuel efficiency of 11 hours at half load. This is accomplished with the 6.42 gallon fuel tank. The battery is included with the TG72B12, which gives you two options of recoil start and electric start on this unit.
The ETQ TG72B12 comes with ETQ Sine Power® this features allows the electricity produce from the unit to be almost as clean as the electricity produced by your home wall sockets. This allows sensitive electronics to be run on the TG72B12.
The ETQ TG72B12 has a heavy duty 1” rolled tube steel design with double bar top frame protection and run flat wheel kit with easy to pull down fold handle. Power outlets included are (2) 120V 20 Amp duplex outlets, (1) 120/240V 30 Amp L14-30R twist lock-outlet, and (1) 120V 30 Amp L5-30R twist-lock outlet.
Features:
Output: 7250 Watts continuous/ 8250 Watts max
Engine: ETQ 420cc 14HP 4-stroke Single Cylinder Air-Cooled OHV Engine
Starter: Easy pull recoil start and hassle free push button electric start with battery included
Outlets: (2) 120V duplex, (1) 120/240V L14-30R twist lock and (1) 120V L5-30R twist lock
Fuel tank: 6.42 gallon fuel tank
Oil level: .9 liters
Decibel sound rating: 70db
Runtime: 6.6 hrs at 100% load and 10.5 hrs at 50% load
Frame: 1’” rolled steel tubing
Wheel kit: Run flat wheels and handle bar included.
Some assembly required
Additional features: ETQ Sine Power®, Low decibel muffler, low oil protection shut off warning, fuel gauge, and automatic voltage regulator (included)
Includes: Funnel and convenience start up tools
Dimensions: 32.68” L x 22.05” W x 23.62” H
Weight: 210 lbs
