Hey guys,
When I open the oil fill cap on our MDX with the engine at idle, there is no air pressure in the cam cover, and I can look straight in and watch the valves move, etc.
But when I open the oil fill cap on our CR-V with the engine at idle, air puffs out the top of the cam cover with a "puff-puff-puff" as the engine idles, and sounds like you're holding a rag over the exhaust pipe.
One of the engines is a V-6 and one is an I-4, but which behavior is normal? Or maybe they're both normal for each respective engine architecture? As I understand it, air will flow into the crankcase through the breather and out through the PCV valve? Would air pressure under the cam cover indicate a stopped PCV valve?
