Originally Posted By: Torrid
Holden calls for 75w140 in their diffs even on the cars. I've run it for that reason. GM NA says that 75w90 is good for the diff now that the friction modifier GM Australia specs is no longer available through the dealer here in the states and the replacement part number is the same 75w90 for the Corvettes. I stick I use Torco RGO 85w140 because I figure there had to be a reason for them to call for the thick stuff.
I also use a 75W-140, but this is because I have a very noisy, and notoriously weak 7.5" 10 bolt rear axle with over 375 hp, and lb. ft. of torque being pushed through it.
I've actually tried the Amsoil Extreme gear
racing stuff (190 weight & 250 weight mixed
), but it either made no difference in noise, or at times actually made the gear scream
worse, so I backed down to the SVO oil.
What size is the ring & pinion in the independent rear's center section on the GTO/Monaro, and is it the same as what's under the back of CTS-Vs, and 5th gen f bodies??
The GTO/Monaro diff is a Dana M80. I'm pretty sure it's a 7.75 9 bolt, but it's only rated to around 400bhp so it isn't that tough for higher modified cars.
Has anyone ever tried to adapt the new 9" IRS center section for the 5th gen Camaros from The Driveshaft shop/Hendrix, etc. to the Monaro/GTO IRS for the higher power beasts??
