This is about my 2001 Dodge Dakota. It's an extended cab, 3.9 liter V6, manual 5-speed transmission, 146,600 miles on it now. I have put 2 sets of front brakes (pads and rotors) on it since I bought it with 41,000 miles on the clock. I check the rear brake shoes and wheel cylinders pretty often, when I rotate my tires every 5,000 miles, and I check them any other time I have the rear wheels off the truck.
Question is, do wheel cylinders have a life expectancy or a given useable service life? The rear shoes are original Mopar shoes and they still have a bit of serviceable friction material left. I admit I do not know very much about drum brakes but I do know it is getting close to time for new shoes.
How often do you guys change brake shoes? How long do wheel cylinders really last? For as little as they cost, I will just replace the wheel cylinders anyway when I do the brake shoes. I will put on new brake drums too. I will be proactive on the rear brakes because this is a job I do not want to do again for a long time.
I can do a very good job on front brakes, I have already replaced my front pads, shoes, rotors twice and I have replaced my calipers too. The rear shoes will be a new experience for me but I am 100% confident I can do it and do it correctly.
Thanks for any info on this.
