Guys, remember when my yota used to drink oil very quick? I used MoS2 during that time, It might improve a little,then I added Oil saver, and it did improve, but not much.
My case was gummed up rings and clogged PVC passages.Thicker oil burned little less, but more smoke, visually.
So trying MoS2, then Oil saver,then thicker oil, then all together is the way to go to find your combo.
