LAB NUMBER: E66447 UNIT ID: ROADKING
OIL
REPORT DATE: 8/9/2011 CLIENT ID:
REPORT
CODE: PAYMENT: CC:
THarley Davidson FLHRCIMAKE/MODEL: OIL TYPE & GRADE: Mobil 1 15W/50
UNIGasoline (Unleaded)FUEL TYPE: OIL USE INTERVAL: 3,549 Miles
2007ADDITIONAL INFO:
PHONE:
FAX:
CLIENt ALT PHONE:
EMAIL:
COMMENTS: Everything looks good in this sample, both for the oil and the engine. Universal averages for thistype of engine are based on an oil run of about 3,500 miles. You ran this oil exactly that long, yet wearmetals were lower than average, so your engine wears better than most. The oil was in good shapephysically, containing no moisture, fuel, or other contaminants. The air and oil filters (silicon and insolubles)
are working well too. The TBN read 7.0, so this oil had plenty of active additive left. 1.0 is a low TBNreading. Try going ~5,000 miles on your next oil fill.
ELEMENTS
IN
PARTS
PER
MILLION
MI/HR on Oil 3,549
UNIVERSAL
AVERAGES
MI/HR on Unit 27,500 UNIT /
Sample Date 07/15/11 AVERAGES
LOCATION
Make Up Oil Added 0 qts
ALUMINUM 4 4 8CHROMIUM 0 0 1IRON 6 6 12COPPER 4 4 12LEAD 0 0 1TIN 2 2 1MOLYBDENUM 114 114 144NICKEL 0 0 0MANGANESE 0 0 0SILVER 0 0 0TITANIUM 0 0 0POTASSIUM 4 4 1BORON 91 91 128SILICON 15 15 12SODIUM 7 7 6CALCIUM 2556 2556 2453MAGNESIUM 42 42 318PHOSPHORUS 1081 1081 1077ZINC 1255 1255 1286BARIUM 1 1 1
Values
Should Be*
PROPERTIES
SUS Viscosity @ 210°F 75.1 75-90
cSt Viscosity @ 100°C 14.29 14.3-18.2
Flashpoint in °F 390 >380
Fuel % Antifreeze % 0.0 0.0
Water % 0.0 0.0
Insolubles % 0.1 TBN 7.0
TAN
ISO Code
* THIS COLUMN APPLIES ONLY TO THE CURRENT SAMPLE
416 E. PETTIT AVE. FORT WAYNE, IN 46806 (260) 744-2380
www.blackstone-labs.com
©COPYRIGHT BLACKSTONE LABORATORIES 2011 LIABILITY LIMITED TO COST OF ANALYSIS
