I have a 2003 GMC Sierra 1500
I have replaced one of the U joints with a greaseable U joint because it was bad.
I am looking for a locally available grease that will be good for the tie rod ends, ball joints, and U joint. I can get another grease to pack wheel bearings on other various projects if need be. I also need a grease for lawnmower wheel bearings, spindle bearings, and string trimmer spindles.
The greases available to me locally include:
Valvoline
Green Grease
Lucas Greases
Super-tech (walmart)
Shell Rotella (Walmart)
Mobil 1
and I believe I have seen Mystik
I have been using the super tech w/ moly but I really don't know a whole lot about greases and wanted to make sure I have a grease that is good for my application.
Thanks. Looking forward to hearing your input.
Valvoline
Green Grease
Lucas Greases
Mobil 1
