When towing (and sometimes without towing) in a few areas across the mountains in East VA there are places where you can (and need to) maintain full throttle for 3 or 4 minutes continuously. Cooling systems are not made to reject that much heat and you can watch the temp gauge steadily climb until you chicken out.
Would I want some 20W oil with the consistency of water in my sump doing heavy towing? No.
Also, if you add a few bolt on parts and re-program the PCM for higher shift points and an increased rev limit (typical enthusiast stuff), you need more protection than a 20W oil can offer when the vehicle is run hard.
The bottom line is that 20W oil is not a high performance or hard engine usage engine oil. It is perfect for its intended usage, but that is not high temperatures under heavy load.
