I drain the oil first so I can burn my arms with the hottest oil. Then while it's draining I go & get a couple "cold ones" to put on the burned flesh. Then not wanting to waste my "icepacks" I consume them. But they are now warmish so I get a cold one to to get the warm taste out of my mouth. Check the oil draining, it's still draining. Hate to waste time, go get another cold on. After I finish that one it's time to put the drain plug back in. I can't remember where I put it, maybe another cold one will jar my memory. I find it 30 minutes later, under the car. Install the plug, developed a thirst, time for another cold one. Jack the car, remove the tire and remove the filter and replace, reverse process. Developed a strong thirst, need more cold ones. Come back out can't find the oil until I trip over it and hit the concrete floor. Need another cold one to ease the pain. Finish job and call doctors office to look at burned arm and concussion. Thank goodness I have a 12 pack
Whimsey
Whimsey
