I recently replaced my master cylinder and flexible front brake lines. In the process of removing the passenger side flexible line, I broke the steel line.
I bought some new line at Napa and bent it up using the proper tools, and used the old line as a template.
As I had no one to step on my brake pedal, and no mighty vac or similar device, I decided I would do a gravity bleed.
It worked fine on the back brakes, However on the front brakes, after 1.5 hours, not on drop of fluid made it past the bleeder.
Since this is on a Van, and I had the front wheels off, I was able to push the brake pedal with one hand and open and close the driver's side bleeder, but even after doing this, the fluid would no flow on it's own.
I enlisted the help of the cable guy to bleed the passenger side, then I did the driver's side myself again.
The brakes are firmer than before. I'm happy enough with the performance, however I am at a loss as to why they would not gravity bleed, even after The cable guy pumped the fluid through the new line.
The Dot3 fluid was warm.
The MC was in the sunlight. It was 85+ degrees
The Van was level.
The reservoir caps were not tightened.
The MC is about 2.5 feet above the bleeders.
The new steel line is not crimped.
I do have a hard time believing there is no air in the system, as the cable guy only allowed me 30 seconds of assistance, but the pedal engages the brakes slightly earlier than before and is firmer, and the thing just stops better.
I do have nearly a quart of new fluid left over. Since brake fluid does not really keep, I plan on bleeding them again with someone to push the pedal this time.
It just, why would the fluid not flow downhill on it's own?
Even when I used clean tubing and lung power to attempt to suck some fluid through, the air was just making it through the bleeder screw threads, and no fluid did.
The old fluid was only slightly dark for the first 8 inches. It was over 2 years old.
Ideas, opinions and humorous insults welcome.
The Van was level.
