1991 Dodge Dynasty. 3.3 liter engine. 134805 miles.
2 qts. Castrol Edge Syn 5W/30
1 qt. Castrol Edge Syn 5W/20
2 qts. Mobil 1 5W/40
1 qt. Pennzoil 10/W30
Carquest 85515. That's why I needed the extra quart. The regular application, an 85085 is Element Dimensions: 3.79 height, 3.66 outer diameter, 3/4-16 inner diameter. Gasket Dimensions: Outer Diameter 2.834, Inner Diameter 2.462, Thickness .200. The 85515 is the same for the Gasket Dimensions, but the Element Dimensions are: 5.178 height, Outer Diameter 3.66, 3/4-16 Inner Diameter, the Height being the only difference.
