I just received this report from a fellow GT500 owner who was using Red Line 5W-50 for 2,118 miles. The car has just over 10,000 total miles. Wear numbers look to be acceptable, but look at how low TBN is, and how high oxidation is.
Did the base stock oxidization increase viscosity and make it appear that it didn't shear much as expected from it's virgin 20.9 cSt spec (VOA tested)?
I would assume the test wasn't inaccurate for oxidation since TBN is so low.
Thoughts and input required. Thanks.
