I bought a 2005 Trailblazer for pretty much parts. The Transmission, would not shift into forward, only reverse, so I removed it and thought this would be a Great chance to see whats in there. Not much. Two big gears, a silent chain(heavy duty chain)two little gears, two simple ball bearings, two engagement dogs and one lever with a pin. This a high/reverse transmission, I imagine the ones with low, have one extra gear. I took it totally apart and put it back together. Not much in there, like I said. The problem was a broken circlip, that when the dog went to engage the top small gear, the clip wasnt there, so it pushed the gear off the big gear on the rod. I ordered a new clip and bushing and it should be good to go. After seeing whats all in there, I am convinced motor oil(any weight) would do fine and that the 11.50 a qt AG oil they sell is a gimic. There is no different metals, no brass, all steel or cast steel. I expected more, quite simple, yet durable design.
