Hello,
I would like to ask yall a question.
I have had no problems with my 2001 GMC Sierra since it was new (can't believe she is over 10 years old now and has 115K!)
Replaced Factory Dexcool twice in 10 years with distilled water and Dexcool.
However, had some PM (All hoses changed, among other things) by a good friend and his mechanics.
And as a favor, they filled up my radiator with "I don't know what".
Now they did fantastic work, but I want to get my coolant back to distilled water and coolant, maybe an additive.
Right now I am draining and adding distilled water every night, after driving it 45 min or so during the day.
I figure it will take me 6 or so "drain and fill" before I get mostly distilled water in there. (Knowing me, I will probably do 8-12, I over do everything!)
Oh, to give you a kind of idea what I do for my engine and tranny, I have used Mobil 1 in both the engine and transmission since the truck was new, and just switched to Royal Purple for both fluids.
So, my questions are:
1. Despite all the "deathcool" threads all over the net, dexcool has been good to me for 10+ years. I was thinking of re-filling it with Texaco Dexcool (after flushing with distilled water multiple times), UNLESS, there is a universal coolant that might even be better than Dexcool. Warantee is out, so "best for my truck" is what I am looking for. So, is there a better long term coolant over dexcool for my GMC Sierra?
2. Should I use a Radiator flush? I know I would have to flush it 6-10 more times after I add the flush, and there does not seem to be any rust.
2. Manual says 50/50 mixture of water/coolant, but I was thinking 70water/30coolant? I live in HOT HOUSTON, TX. Freezing is NEVER an issue here! I have a 4.8 V-8, and manual says that Cooling System Capacity is 13.4 quarts. Instead of going 50/50 mix (6.7 Quarts) I was thinking of going to only 1 gallon Dexcool (29.8%), to get a little better cooling. Note, I am NOT having any overheating problems now, but cooler is better, right? However, 100% distilled water is not good for long term care. Thoughts?
3. What about additives? Water Wetter, Purple Ice, Kool-it, I have heard them all called "snake oil" but all three are from reputable companies. I was suprised to see that LubeGuard Transmission additive is recommended here.
I think I know the answers, but I would like to get your opinions.
Here are my "answers" by the way.
You are not having any cooling issues, and do not have any rust coming out when you drain, so after you have flushed enough distilled water thru your truck (make sure you turn that heater on to get a good flush!), add 6.7 quarts of dexcool to your radiator system, and top it off with distilled water, and enjoy your truck for the next 10 years. Getting better cooling by reducing coolant, or adding additives, might give you slightly better temperatures, but may sacrifice long term reliabality. What good is 10-15 degrees if your water pump dies early, or if your radiator rusts.
(Man, I hate reading that answer! - I almost don't want to post this now!)
I still welcome your opinion, there are some really smart people here!
Thanks!
Thanks!
