Oil recommendation for 2002 Subaru Outback 2.5L
All the good suggestions have been suggested already. Any name brand 30 or 40 weight oil will run great in that engine, conventional or synthetic. I haven't personally used the cooling system conditioner yet, but I suppose I should start now that I've got about 60k miles on the clock.
Originally Posted By: tired
What's this about an HG issue? What's HG? Looks like I'll have to find a DIY for a coolant flush now too. I'm used to my VW which claims that the coolant is a lifetime fluid.
Thanks again. Glad I found this great community.
Subaru recommends changing the coolant every 30,000 miles and adding the conditioner. The conditioner is cheap, I paid $3.75 for it at the dealer. For coolant, I recommend the Zerex Asian formula, or genuine Subaru coolant if you can't find that (that's not cheap, $24 for a gallon, but that's more than enough).
DIY and lots of other specific info for your Outback is available over at subaruoutback.org
