Originally Posted By: HeavyAssault06
There is an issue related to the 6.0 Ford that I'm trying to understand better. I've found that Ford says EOT normal range is -40 to 302. I wasn't sure at what temp the oil looses it's properties and/or effectiveness. I've read a few oil product sheets and see a viscosity rating but wasn't sure how to relate that to operating temperature.
I'm currently using Valvoline Extreme Blue and use ROT T6 as well. Any additional help is appreciated!! Thanks for the current info!!
Now that I understand your question better I can give you a better answer.
According to the 6.0 gurus you should start to back out of the power at 235f EOT, at 253f EOT the 6.0 will begin to defuel per computer command. So even with your EGR cooler removed, and if your oil cooler is plugged yhe computer will save the internal componets.
I am well aware that oil by itself is able to withstand higher operating temps, but in this specific application Fords computer overrides your right foot.
The issue isn't the oil temp, its the difference between engine oil temp and engine coolant temp. On the 6.0 when the oil cooler begins to plug up with debris from the coolant system it starves the egr cooler for coolant, which in turn flash boils the coolant in the coolant starved super hot egr cooler.
Steam in the coolant system leads to the egr cooler ruptering along with head gaskets leaking. It is very important to monitor ECT vs. EOT in a 6.0. A bypass coolant filter is a very good investment. Many are using a scangaugeII to monitor temp differental, any more than 15f at 65mph unloaded is signs of an oil cooler beginning to plug.
The Ford TSB states to run a road test at WOT/Heavy Load to see the delta between EOT/ECT. 65mph unloaded is VERY conservative.
Your correct about the ECT/EOT issue on stock trucks. My research is regarding trucks with a deleted EGR cooler. The "delta rule" doesn't apply at that point since the EGR cooler is gone. SO with the EGR cooler gone what's the limit of temps I should see for my EOT. The Ford manual states that the EOT normal range is -40* to 302*.
