recently received an oil analysis on 2 cat 3116, 1997 year with about 2000 hours each. analysis was done by catepillar. report shows elevated sodium (142 ppm)in port engine, all other readings normal. the engine has historically had sodium readings around 6-7 ppm. the rport shows "p" (present) for antifreeze. according to the cat service manager, this p is not a specific test for glycol, but a indicator based upon the elevated sodium. the fact that no other readings are elevated, potassium, etc seems it might be a bad reading. they are recommending oil change and retest in 20hrs. i am inclined to have another analysis done? help?
