An Alignment to me is adjusting all readings to Factory Spec, not within spec, but right on the spec.
Now for the Better Shops that is not a problem. They can go even further and customize your alignment setup based on your needs. IE: Better than OEM.
Quick Story, I was once calibrating an aligner at one of the National Tire Stores, you know the... We Can't Fix Anything Shops. In the course of my calibration, they continued to use the aligner in the next bay over. All of a sudden, I hear the Tech hollering... PUSH PRINT, PUSH PRINT. I looked over to find his hands on the front wheel aligner clamp, Bringing the readings into the green. Well the customer really got his moneys worth that day.
As I have said before, Seek out a shop that does only alignments. They are out there, and worth every penny.
Jim
